98 Accord Trouble after cleaning Throttle Body
Old Dec 12, 2012 | 08:01 PM
kevin1321's Avatar
Default 98 Accord Trouble after cleaning Throttle Body
Hi,
I am having some difficulty with my 1998 accord 2 door ex. I cleaned the throttle body (left on the car), sprayed and wiped with carburetor cleaner. I made sure not use too much and wiped and cleaned everything. Everything was reattached, and I started the car. The car idled pretty rough and the CEL began to blink. The car ran for about 5 minutes, then I reset the CEL. Then ran it for another couple minutes. The code reads P0301(71 Misfire Cyl. 1 Or Random Misfire). Any suggestions on how to fix this? Also filled anti-freeze while I was at it
Old Dec 12, 2012 | 08:26 PM
This is a 4 cylinder, correct?
Although you didn't stated any trouble code directly related to the throttle position sensor, did you remove the connectors for the TPS and MAP sensor?
Sometimes people inadvertently switch them. I believe the MAP sensor connector is gray and the TPS sensor connector is blue.
Attached Thumbnails 98 Accord Trouble after cleaning Throttle Body-98-00-throttle-body.jpg
Old Dec 12, 2012 | 08:58 PM
kevin1321's Avatar
Correct, this is a 4 cylinder, and I did remove the connectors and reattached. The connectors were in the right position
Old Dec 13, 2012 | 08:32 AM
Dr. Drivability's Avatar
first thing, you shouldn't use carb cleaner on a FI car, they make throttle body cleaner specifically for that purpose. start by pulling the plugs and checking them out, replace them while your at it. report back.
mclasser
Dec 28, 2013 10:49 PM
98accordpain
Oct 17, 2012 07:05 PM
NemoTeacup
May 5, 2012 07:47 AM
jose310
Feb 3, 2008 04:31 PM
Accord_Ras
Dec 10, 2007 07:19 AM
