98 accord wont rev over 2500rpm
Old Oct 16, 2012 | 10:18 PM
peat-moss's Avatar
Default 98 accord wont rev over 2500rpm
R&R'd engine to replace clutch, reinstalled, started immediately, idles rough, and wont rev over 2500rpm. No codes or check engine light. Answers or ideas on how to fix?
Old Oct 17, 2012 | 06:53 AM
Check your wiring harness connections?
- CKP/TDC sensor connection is down low on the timing cover - did you forget that one?
- Two sensors (TPS & one other?) have same plug - common mistake is to swap those wires.
Old Oct 17, 2012 | 03:37 PM
peat-moss's Avatar
Thanks. All that seems to look ok.
Old Oct 18, 2012 | 07:37 PM
The TPS and MAP sensor on the TB are the same size and shape. What color are the three wires that are plugged into the TPS - Should be GRN/BLK, RED/BLK and YEL/BLU
Mario Locatelli
Apr 3, 2014 07:54 PM
Cjohnson700
Mar 29, 2013 06:46 AM
Rocksedge
Mar 17, 2013 04:07 PM
blakeryanfarris
Dec 6, 2012 12:13 PM
