98 honda accord driver seat fell back.
Old Sep 26, 2013 | 06:23 PM
jadwinsmo's Avatar
Default 98 honda accord driver seat fell back.
While doing some work under the dash I had the coupe drivers seat layed back althe way for room. Now the seat will not lock in the upright position, just fall back into the back seat of coupe. I picked up an exploded parts view but can't really see what I need to do. Searched the site and found all the other issues, but not mine. Would gladly appreciate the help. The seats on this car are power but the latch is mechanical. Thanks in advance.
Old Sep 26, 2013 | 06:45 PM
Is the driver's seat manual, powered (2-way), or powered (8-way)? Side airbag, yes or no?
Old Sep 27, 2013 | 03:48 AM
jadwinsmo's Avatar
There are two switches on the side, so a two way I assume, I don't believe there is a side air bag, no.
Old Sep 27, 2013 | 10:46 AM
Sounds like you have the 8-way powered seats. 2-way only goes up and down.
You may have to remove the driver's seat first to see what the problem is. It is a problem with or at the recline adjuster; but, check that the bolts are not broken or damaged at the recline adjuster or if there may be something you can do to make it work properly again.
To remove the seat to examine the recline adjuster and bolts:
1. Position the driver’s seat for removal:
• Adjust the seat to the middle of its tracks.
• Adjust the seat cushion height all the way up at the front and rear.
2. Make sure you have the anti-theft code for the radio, then write down the radio station presets.
3. Disconnect the negative cable from the battery.
4. Remove the driver’s seat. There are four bolts that hold down the seat tracks. Pry the plastic covers off the seat track ends, then remove the 4 bolts. Then lift up the seat and disconnect the electrical seat harness connector.
5. Carefully pry off the two switch ***** from the seat,then remove the recline cover (three screws) and the height outer cover (three screws). (See attached pic. for cover removal.)
The recline adjuster part varies depending on your specific model; but, it is like part #6 in this diagram. If it needs replacement, it is not cheap new; so, salvage yard may be a good option.
Attached Thumbnails 98 honda accord driver seat fell back.-recline-cover-removal.jpg   98 honda accord driver seat fell back.-front-seat-components-l-4-way-power-seat-456686.jpg
Old Sep 29, 2013 | 02:17 AM
Honda-Master's Avatar
most likely you got an issue with # 6 ,make sure that the bolts are all in and are tight
Old Oct 1, 2013 | 01:32 PM
jadwinsmo's Avatar
Default Fixed
After following directions and looking at the seat minus the housing covers I was able to not only clean the mechanism, but also get enough change for lunch. After putting back together and reconnecting power, the seat went from a full recline to the standard driving position with out a hitch. Both answerrs were extremely helpful.
jza240sx
Apr 30, 2013 04:14 PM
mpk
Dec 13, 2012 01:41 PM
MysticBlueEX
Feb 18, 2011 06:55 AM
anlam3
Nov 10, 2008 09:11 PM
mbanwait
Jan 2, 2008 12:25 PM
