99 Accord 2.3L Oil leak
Old Sep 7, 2009 | 07:34 PM
cyberdork
Default 99 Accord 2.3L Oil leak
I have the 4 cylinder in my 99 and have a leak in the rear of the motor. It drips down onto my exhaust and makes a smelly mess. It is a very slow leak but constant. Any ideas of what it could be?
Old Sep 8, 2009 | 08:42 AM
There's just a couple things back there for you to check...
Oil filter gasket would leak directly down onto the exhaust.
Just above the oil filter is the oil pressure switch. That's a sorta-common place for a slow oil leak (through the middle of the sensor).
If there's evidence of oil ABOVE the pressure switch, then check out the valve-cover gasket. Or the head gasket.
Old Sep 8, 2009 | 04:37 PM
cyberdork
I've put multiple filters on throughout the period of the leak so I'm going to rule that out.
Old Sep 8, 2009 | 05:07 PM
Clean it up real good & look for the highest elevation that gets oily.
alltime3rdwheel
Dec 31, 2012 10:46 AM
frost506
Jan 16, 2012 07:21 PM
MiyashiMeism
Sep 5, 2010 02:12 PM
mamtsberg
May 30, 2010 07:04 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
