99 accord clutch problem
Old Jun 23, 2012 | 04:38 PM
MEATBALL69's Avatar
Default 99 accord clutch problem
just bought a 99 accord with clutch problems! im able to shift trans in to all gears with out pushing clutch to floor no grinding and car will not move at all! want to make sure its the clutch n not something else that not allowing clutch to engage! clutch pedal feels good and comes back up n sc seems to be working as it should! thanks for any help i can get!
Old Jun 26, 2012 | 01:41 PM
First, this area is for questions about the website, not about the cars. I'll move it to Gen.Tech.
Sounds like your clutch is completely gone. But that's unusual. Normally they gradually begin slipping and slowly get worse.
Check whether one of your axles has popped partly out from the transmission. It's also possible that the center hub area of your clutch disk has broken in a way that allows it to spin completely free.
When you lift the clutch pedal (in gear with engine running), what does the speedometer do?
vetski179
Feb 24, 2015 04:26 PM
jkrueger2020
Mar 10, 2011 02:18 AM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
