99 Accord EX coupe V-6 dies shortly after starting. No CEL codes
Old Dec 30, 2019 | 03:40 PM
jbnnthorn's Avatar
Default 99 Accord EX coupe V-6 dies shortly after starting. No CEL codes
I have a 99 Honda Accord EX V-6 with 287,000 miles on it that starts and quickly dies. If you wait a longer period of time to try restarting it will run for a bit longer. It sat outside for about a week between being started in temperatures that were below freezing one or two nights before this problem started.It has 1/8 tank of gas. If I get it started and try to apply gas it immediately dies. Unplugging the IAC does not change anything. Trying to jiggle the key when it is running does not change anything. The cap and rotor look OK. The spark plugs look newer and the gap in the one I pulled was correct. Eric the car guy made the comment that rarely do Hondas have fuel pump failure. I can hear the pump come on and it sounds normal.
Any suggestions on what to check?
Old Dec 30, 2019 | 06:41 PM
Your next step would be to test for spark with a spark tester or old spark plug while you have an assistant try to start the engine.
You may want to add a few gallons of gas to your gas tank and add a gasoline antifreeze like Heet to the tank.
Old Jan 1, 2020 | 01:35 PM
jbnnthorn's Avatar
Thank You. I added Heet and 4 gallons of gas and it started and ran rough for a few minutes then smoothed out.
Old Jan 1, 2020 | 09:25 PM
rockhoundrob's Avatar
Just a few ideas...
1) you have 1/8 tank of gas. It's possible you had condensation collect in the tank and water it preventing it from running well. Try filling up the tank with gas.
2) your problem shouldn't be something like bad spark plug. 1-2 sparkplugs won't make an engine quit. it's either NO spark, or no fuel.
3) do you have a camshaft sensor? If it is bad, it would make ALL your injectors stop working.
4) Your said you checked your distributor cap. Maybe it's the ignition coil?
5) what about a clogged fuel filter?
Old Jan 2, 2020 | 12:15 PM
His previous post was that he added 4 gallons of gas and heet and the engine smoothed out, so I think his problem was solved.
Old Jan 2, 2020 | 04:09 PM
The Toecutter's Avatar
Yeah, that low fuel level will get you every time. I've even done that on my Chevy Astro van.It really makes you feel like an idiot.
Jim Vader Leslie
Apr 12, 2018 06:43 AM
djfalcon
Mar 1, 2015 12:28 PM
cawb09
Apr 11, 2009 11:58 PM
sillemij
Aug 21, 2007 10:51 PM
collierville
Mar 5, 2007 10:17 AM
