99 Accord rear balance shaft lock up
Ok yes I know this has been covered and I did search and found a answer pertaining to a 92.
Problem I have is trying to lock the balance shaft.
I followed the instructions and marked a 6mm allen wrench at 2-29/32".
Made sure the engine was at TDC.
Tried to insert the allen wrench to my mark and it came up short. So I tried to rotate the engine around to TDC again as the 2 rotate at different rates. Still not able to insert the allen wrench. I repeated this 5 times and had the same result. What am I doing wrong? I know It's at TDC as all pullys alighn up as they should. I just cant get the the rear balance shaft to lock up using the allen wrench.
The car is a 99 Accord EX with the F23A1 VTEC engine
wolfverine37
Nov 29, 2012 03:04 PM
