99 Accord Spark Plug Tube, Pulled some piece out. Not sure what it is.
Old Apr 14, 2013 | 07:09 PM
CCC's Avatar
CCC
Originally Posted by JimBlake
In between the "X"s in your photo is a corner/edge. Put a little on that corner. It's less important to cover the flat surfaces with "X" as long as you get some on that square edge. Just a little is needed. Too much will ooze out & harden into globs inside your engine.
The rubber corner is not "sharp" enough by itself to get into the seam between the 2 metal pieces. (the seam between the head itself & the cam-bearing cap)
Now for those tube seals...
Make sure you haven't scratched up the metal surface with that screwdriver. That would make a leak path. If you have any scratches (especially deep gouges) use a little bit of grey goop there too.
This looks worse than it is due to bad focus but would it need the goop treatment and if so would I dry the goop before installing the seal because I was planning to help that process with a coating of oil. Note all I did here was touch screwdriver to rubber and tap until it fell out, don't know how that could scratch.
Old Apr 15, 2013 | 06:56 PM
Light coat of oil and you should be good to go.....I'm hoping that is the tube seal area.
Old Apr 15, 2013 | 10:30 PM
CCC's Avatar
CCC
Yes. The brightest aluminum is where the seal rests and the area above it is the walls that hold the seal. So just oil and not sealant + oil. Good to know. I was worried it would leak. Thanks.
spivieguy1
Feb 6, 2013 12:48 PM
kain9i6
Mar 16, 2012 03:19 PM
tlhfirelion
Mar 2, 2008 09:57 PM
kornfox
Feb 6, 2007 04:56 PM
brave_mhy
Aug 23, 2006 04:35 AM
