99 EX Coupe No crank no start
My car, a 99 Accord EX coupe manual with a 2.3 VTEC has been having an intermittent starting problem. Battery and alternator are fine, I've replaced the starter and tried bypassing the clutch safety switch with no luck. Occasionally it will start just fine but other times the starter won't even click but all my dash lights come on but dim when I move the key to the start position. When the starter won't go I just end up roll starting it and it runs fine without any stalling problems. Could it be a starter relay or anti theft issue? I've heard main relay but I can hear the fuel pump run and most people with that issue it sounds like their car will crank.
It could be a bad rebuilt stater, as that's pretty common these days. Or it could be an anti-theft system, if you have one (like an aftermarket system). The next time it does it's no start thing, put the trans in neutral, and using a screw driver jump the 2 wires on the starter solenoid and see if it starts. If it doesn't, then it's the starter. If it does, it could still be the starter, as it's drawing too much power (lights dim while trying to start). Let us know what you find.
If you supplied power to the small starter wire that is blk/wht, then the starter is not the issue.
The issue is likely the electrical portion of the ignition switch. Another cause could be the clutch switch. You can try bypassing the clutch switch, but I don't have a wiring diagram on this computer to give you specifics on how to do this on your car.
xang0
Jul 6, 2009 03:22 PM
dimbee
Oct 12, 2007 02:52 PM
