99 Honda Accord EX Power Window Mystery
Old Sep 17, 2011 | 09:24 PM
ghostpilot's Avatar
Default 99 Honda Accord EX Power Window Mystery
Hi folks,
I have a peculiar problem that is a mystery to me. My passenger side window will go down but not up from the drivers side master switch. I have replaced the regulator and it wasn't that. I replaced the window switch on the passenger side because apparently that was broken and now the window works great from the passenger side but the problem still persist from the drivers side. I bought a used master power window switch from E bay and connected it and it has the same problem so that leads me to believe its not the switch. Any ideas?
Old Sep 18, 2011 | 06:38 AM
Are the door locks acting up? Anyway, doesn't quite sound like the same as what I have seen before when the multiplex "goes to sleep". Might try to reset it, does't cost anything but a bit of time.
1. turn the ignition switch off
2. turn the wiper intermittent time ring to the middle position.
3. turn the ignition switch to on. -on NOT Started
4. check the operation of all the power windows from the master
power window swtch and the power door locks.
Again, usually the locks are acting up, worth a try. If this doesn't help let us know and we can go for more testing.
Old Sep 19, 2011 | 07:21 PM
ghostpilot's Avatar
Thanks poorman212 for the suggestion but unfortunately it did not work.
This really is a mystery. This window problem is really annoying. Thanks for your suggestion if you have any others let me know. Thanks.
Old Sep 19, 2011 | 08:02 PM
Most likely a faulty connection from Master Control Panel to door wiring harness. You can test by jumping the Down wire and Power supply wire near the switch connector (master panel). You will need a sharp pin/nail to penetrate the wires and jumper the switch.
On my 94 Accord manual wire colors were blu/blk power feed to switch and Blu out.
If you unplug the entire master switch panel and jumper the connector pins, I don't think the window will work becasue Power Window Relay will be open. You could jumper the Power Window relay and try connecting wires at master switch connector. You would also need to jumper ground to main switch panel.
You will absolutely need a wiring diagram for your power window setup.
Old Oct 4, 2011 | 03:10 AM
Phobia's Avatar
Did you ever find out what was wrong??? I have a similar problem, all my windows will go up and down BUT my passenger front door window only go down if you press the button on its door. If you try to put it down with the drivers button it will not go down only up. I got kinda used to it but I would like to fix it. Also my drivers rear door lock will only work 50% of the time when it feels like it, I also got used to it lol
Old Oct 4, 2011 | 06:33 PM
Faulty or dirty switch in the master control panel. Recently, a poster was able to remove and clean the switch. A search might find the post.
Old Oct 4, 2011 | 07:57 PM
Phobia's Avatar
The master control pannel would be this right???
94-97 ACCORD MASTER WINDOW SIDE SWITCH POWER DARK BLUE | eBay
Old Oct 5, 2011 | 02:45 PM
ghostpilot's Avatar
Hi Phobia,
No, unfortunately I still have the problem. Although I did take it to a local nmechanic and he made the same suggestion that TexasHonda made which was a bad wire from the master control to the door wiring harness. I actually plan on working on this problem this weekend now that my honeydo list is done.
Thanks for all your help to everyone on this forum I will write again with updates after this weekend.
millmeg
Mar 22, 2015 03:09 PM
acpike
Jan 29, 2013 10:43 PM
jkeely
May 2, 2012 03:48 PM
swayzak
Feb 22, 2008 11:27 AM
mmazb3
Nov 26, 2007 03:16 PM
