99' oil in coolant
Old Aug 31, 2009 | 01:37 PM
jacks132
Default 99' oil in coolant
I need some advice! I have a 99 accord lx with 164000 miles. It recently developed a crack in the top of the radiator without me noticing it until it started overheating. Upon me noticing the problem with the radiator I noticed that it had oil in the coolant reservoir. I have been reading some other forums about head gaskets and porosity cracks in the engine block. My assumptions are that when the car was overheated, it blew a head gasket. I am thinking that if it was a porosity problem it would have possibly done it a long time ago. There is no coolant in the oil that I can tell and car runs great. This is why the porosity problem has me worried.Can anyone help, I am debaiting on trying a head gasket before engine swap but would like some quality advice, thanks J
Old Aug 31, 2009 | 02:55 PM
deserthonda's Avatar
have a shop do a cylinder leakage test ,, most likely a blown head gasket,warped head ??
Old Aug 31, 2009 | 11:56 PM
jacks132
I dont meen to sound stupid but I have never done a cylinder laekage test, just a cylinder compression test. How long do you test each cylinder and im assuming that I use compressed air????How much pressure?
Old Sep 1, 2009 | 12:11 AM
you need to have a leak test gauge set up to do the test and yes you do need to use compressed air.. if you do not have the equipment you might want to have a shop do the test
Also i deleted the exactly other post that you wrote,, there is no need to have 2 posts asking the exact same question it is a waste of space
MiyashiMeism
Sep 5, 2010 02:12 PM
ianhillsman
Oct 10, 2009 01:30 PM
dyeballer26
Sep 3, 2009 10:49 AM
wietgr
Aug 23, 2007 11:22 AM
Dhorn33
Jan 12, 2007 04:53 PM
