99 overheating.
Old Jul 10, 2015 | 02:32 AM
savatage4's Avatar
Default 99 overheating.
I have a 99 accord 2.3 auto that will not stop overheating. replaced waterpump, timing belt, thermostat, cylinder head, head gasket. I drive about 20 miles on freeway and notice its starting to go above halfway mark, so I exit then it really starts shooting for hot (max). hoses feel like theyre going to burst, you hear gurgling like its boiling. turn it off, let it sit for 20-30 min. start car and start whole scenario all over again. any ideas?
Old Jul 10, 2015 | 06:53 PM
When the engine is cold, remove the radiator cap and verify the radiator is filled with coolant.
Old Jul 10, 2015 | 10:36 PM
savatage4's Avatar
Thanks for the response. yes. Its full of coolant. I also forgot to mention radiator is about 2 years old
Old Jul 11, 2015 | 06:05 AM
turbofrank's Avatar
Air in system does your year car have a bleed valve ?
Old Jul 11, 2015 | 04:28 PM
Did you reuse your old radiator cap when you go the new radiator?
Old Jul 13, 2015 | 06:23 PM
savatage4's Avatar
sorry for taking so long to get back. busy, busy. response 1, yes it does have a bleeder valve, did that. response 2, put new cap on radiator. im stumped. Thanks for the replies.
Old Jul 14, 2015 | 05:42 AM
Turtlehead's Avatar
Check that the thermostat is installed properly. Spring side goes into the head and that the bleeder pin on it is up. You can also take it out, put it in a pot of water, start heating the water and using a thermometer see what temperature it opens at. When you re-install, be sure to bleed the head at the 12mm bleeder bolt until all air is out and fluid flows free of bubbles.
Old Jul 14, 2015 | 10:13 AM
W/ a cold engine start and run engine at 1500-2000 rpm w/ radiator cap off. If coolant starts to flow up/out of the radiator and bubbles appear, a failed head gasket is very likely.
A cold engine cooling system leak test can confirm head gasket leak; no external leaks and pressure steadily dropping.
copa708
Apr 24, 2006 08:36 PM
mennerja
Jan 6, 2006 10:03 PM
erikhaha
Nov 20, 2005 02:48 AM
jordan
Sep 6, 2005 11:35 PM
Getsch
May 24, 2005 07:52 PM
