ABS at low speeds, 2007 Accord
Old Jan 27, 2013 | 06:10 PM
nachos4's Avatar
Default ABS at low speeds, 2007 Accord
2007 Accord SE, Auto, 37k miles. Original brakes.
Recently the brakes feel like the ABS is engaging when I am going very low speeds, like 3 to 5 mph. At the end of my driveway, which is on a slight downslope, I can feel it. Not every time, but most of the time. Also at other times, such as in a parking lot going very slow speeds.
Once I get going 10 mph or above, the brakes work just fine. Any ideas?
Old Jan 28, 2013 | 05:55 PM
Does this seem to happen after the car has sat for long periods of time....a few hours, say ~5?
PS - Welcome to HAF
Old Jan 29, 2013 | 07:19 AM
nachos4's Avatar
Not always. Yesterday morning I drove home from work, the car sat in the garage for an hour, then it did it again when I drove down the driveway.
Old Jan 29, 2013 | 10:41 AM
Dr. Drivability's Avatar
could be a boogered up wheel speed sensor. if you're handy, it's fairly easy to pull them out, clean'm and stick'm back in.
Old Jan 30, 2013 | 07:52 AM
nachos4's Avatar
Thanks! I was kind of thinking that might be the problem. I think I can get to the sensor. But how do you suggest I clean it?
I found this youtube video that shows how to get to the sensors (put on mute - the music is terrible).
Old Jan 30, 2013 | 08:28 AM
The sensor is magnetic, so it can build up a pile of metal shaving. Usually there's one bolt & the sensor comes out of the knuckle. Could be stuck with corrosion?
Old Jan 30, 2013 | 08:35 AM
the ear that fastens it to the knuckle is plastic and can break...spray some penetrating lube on it first.
getsch
Dec 26, 2012 04:13 PM
nickmg555
Mar 6, 2012 07:26 PM
kakarotoni
Sep 14, 2010 07:12 PM
Nitin
Apr 20, 2008 07:19 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
