ABS sensors...
Old Jun 17, 2007 | 05:43 PM
Green_Accord's Avatar
Default ABS sensors...
Hi all
Does anyone know where those abs sensors are on a 2001 honda accord V6 sedan?
The reason I asked beause both ABS and TCS lights are on in my car. I talked to SEVERAL mechanics and they said it's because of the ABS sensors. Please help before i'm going broke trying to fix the problem.. thanks
Old Jun 17, 2007 | 10:31 PM
Default RE: ABS sensors...
They'rebehind the brakes. Which wheel sensor (front/rear)?
Follow the electrical wire on the steering knuckle. The ABS sensor is the only electrical thing near the caliper. The business end of the sensor sits almost touching the toothed ring around the CV joint.
Old Jun 18, 2007 | 03:53 AM
Thanks a lot.. i'll try it today and see wat happen
Old Jun 18, 2007 | 06:55 AM
Chiovnidca's Avatar
ORIGINAL: Green_Accord
Hi all
What trouble code does it have stored? Throwing speed sensors at it will get expensive.
Old Jun 20, 2007 | 08:14 PM
I have no idea.. I just brought it to a mechanic and he told me that there was 6 trouble codes coming from the right front wheel but he didnt tell me what they are. He just told me it's the abs sensor causes those problems and charged me $40 for the diagnosis. I took my car home .. took the wheel off and found the electric wire like Jim Blake said and found the sensor but I have no idea how to remove the sensor. It has one 10mm screw hold it to the steering knuckle, I removed the screw but have no idea how to remove the sensor and i'm so frustated .. anyone know how to remove the ABS sensor.. please help....
Old Jun 20, 2007 | 11:47 PM
It should pull right out after the bolt is out. It's probably stuck with rust?
Old Jun 21, 2007 | 12:16 AM
I did try to yank it out a little bit but couldnt get it loose .. it looks like its leg somewat contact to the CV joint.. i'll take the pics tomorrow and post it in here ....
93Accord2.2
Nov 7, 2013 07:10 AM
g-slide
Oct 12, 2010 08:36 PM
DMN_RITE
Apr 20, 2007 03:27 AM
enerlevel
Sep 5, 2005 02:26 AM
Rasher
May 17, 2005 01:19 AM
