ac clutch mystery
Old Apr 22, 2018 | 03:04 PM
TexomaAccord's Avatar
Default ac clutch mystery
1997 honda accord v6
bla bla, let guy borrow car (we know what happened)
but during that time, the a/c belt broke
now after the rebuild, I decided to replace a/c belt
installed belt, started car, turned on ac and belt started smoking
removed belt
disconnected white/red wire from a/c black wire
can spin pulley with hand
jumped 12v hot to black wire on a/c and it just sparks where I touch the wire
a/c clutch not engaging
hooked ground to body of compressor and to neg. battery
touched 12v to black wire on a/c... still spark, not engaging
system is full of freon
need new compressor? need new clutch?
Im running out of money (now that my heads are being replaced on my explorer)
anymore test I can do to determine what I need to replace.
I do not want to replace the ENTIRE compressor if I don't need to
Thanks guys
Old Apr 23, 2018 | 10:13 AM
If the pulley binds only when the a/c is turned on, then I'd think the clutch is working and the issue is with the compressor possibly binding.
You can try turning on the a/c with the engine running and no a/c belt on. See if the compressor pulley spins. Be very careful because you can get hurt if you come in contact with the other moving parts on the engine.
I've taken apart a compressor on my 95 4-cylinder and it is a pretty simple setup inside.
Old Apr 24, 2018 | 08:42 AM
Ahhh my fingers!!!
If it doesn't spin, then what?
Can I beat on it with a hammer?
If it does spin, then what?
Old Apr 24, 2018 | 01:04 PM
The Toecutter's Avatar
Originally Posted by TexomaAccord
Ahhh my fingers!!!
If it doesn't spin you can hit it with a hammer as it's kaput (yes they do go bad). The AC compressor in my son's Civic seized and locked the engine. Cutting the belt allowed the car to run again. He's since gotten a new compressor.
If it does spin, I guess you're rebuilding it, or looking elsewhere.
Old Apr 24, 2018 | 02:20 PM
Ok, come check it.. I really am tired of working on cars.. gimme boats! I resealed the distributor yesterday.. woo hoooough....
Old Jun 22, 2018 | 07:57 AM
replaced with new a/c compressor.. bleh.
SirRaunaldi
Sep 3, 2012 02:22 PM
daddy
Oct 12, 2010 07:17 AM
drummer1279
Mar 18, 2007 07:07 PM
tamb
Jul 21, 2006 01:05 AM
avrillu
May 17, 2006 09:14 PM
