ac diagnoses step by step
Old Jul 25, 2008 | 12:24 PM
falkore24's Avatar
Default RE: ac diagnoses step by step
Just don't get frustrated if you don't get answers quickly. Most of the members here are on when they are slacking off at work. I'm rarely online during the weekend .... and I'm taking off Mon. and Tues.
Old Jul 27, 2008 | 09:12 AM
maro's Avatar
Okay, so no fans come on And I hear nothing when engaged
Next step?
Old Jul 29, 2008 | 10:12 AM
maro's Avatar
up..
Old Jul 30, 2008 | 08:42 AM
maro's Avatar
so.... can anyone help me see through to the next step in diagnosing my ac
thanks guys
Old Jul 30, 2008 | 09:48 AM
deserthonda's Avatar
try an easy test, find the pressure switch located rt side frt of car by the rec drier , unplug the connector, jump the 2 wires together ( blue/yellow and red/white ) if fans and compressor engage most likely system is out or very low on freon ,,,,,
if you have a set of gauges you can hook them up and chk the pressures
try this first and let us know
Old Jul 30, 2008 | 11:32 AM
maro's Avatar
okay, I'll jump those buggers. I'll say this... though, I've tired using a ac re-charge, and it said I was all charged up. So I'm thinking it's something else.
Old Jul 30, 2008 | 11:46 AM
  #17
Do you mean a recharge bottle with its own little pressure gauge?
Then maybe it IS something different.
A manifold/gauge set is better because it shows low AND HIGH side pressures. If the pressures are good and it works when you jumper the pressure switch, then its probably a bad pressure switch.
Old Jul 31, 2008 | 09:59 AM
  #18
1993solace
Auto Zone stores have or can get U a DVD titled "Diagnosing and Repairing Air Conditioning Systems" part #ACVID1and it costs very little. I too am a noob and it helped me alot. The store also offers a loan-a-toolprogramif you need guages, system flush kit, etc.
Old Aug 1, 2008 | 09:15 AM
  #19
maro's Avatar
Default Image Attatched
Where is my pressure switch? Here is a photo with circled areas numbered.
Old Aug 1, 2008 | 10:06 AM
  #20
Default RE: Image Attatched
#16.
Will_V
Mar 5, 2020 11:55 PM
Restless
Jun 4, 2013 12:09 PM
g22cd5
Sep 27, 2011 08:57 AM
