AC Electrical Problem
Old Apr 14, 2013 | 09:12 PM
halcyon's Avatar
Default AC Electrical Problem
There is a single wire (red) that powers the AC compressor clutch. Check whether it has 12V when AC is commanded on.
If no voltage, the AC compressor relay, pressure switch, or ECU can disable compressor. Pressure switch would disable if the charge has been lost or pressure switch is defective.
If you have 12V to the clutch, the clutch plate gap is likely excessive or clutch coil is open. Both can be repaire (w/ some difficulty) w/o discharging the system.
not to hijack your thread crispin, my appoligies ,for Texas Honda having a strange issue with my fans. would like to know if it is possible that a fault in the ecu could be causing my fans to run without a signal from the coolant temp switches A and B? I'm grasping at straws here after 8 hours of trouble shooting.
thanks
Old Apr 15, 2013 | 11:58 AM
Don't apologize. Don't enter a separate question in another thread. Read posting rules.
Start your own thread w/ your info and description of problem.
Unlikely an ECU fault, but could be a fault in the cooling system timer (forget correct name).
calenatar
Mar 10, 2006 03:23 PM
eddyfurukawa
Feb 13, 2006 03:15 PM
qbtarget
Feb 13, 2006 01:56 PM
dude9571
Feb 11, 2006 12:17 AM
Mydnght2u
Jan 17, 2006 07:18 PM
