AC/ Heat not working
Old Jun 22, 2022 | 09:37 AM
DJ1983's Avatar
Default AC/ Heat not working
I have a 08 Honda Accord . Heat and AC is not working . Driver side radiator fan not turning on , passenger radiator fan IS on. AC light does turn on and off. When switching temp from hot to cold I hear what sounds like a fan trying to Engage. But nothing . If I am driving fast I can feel little heat or air , but otherwise nothing. Have replaced blower motor and fuses under hood to no prevail. Don’t know if this anything to do with it, but I jump started my wife’s daycare little bus. If anyone has any ideas of what I should try next .. I would greatly appreciate it.
Old Jun 22, 2022 | 12:07 PM
Moved your post to a new thread. 2 problems on one thread is confusing.
What do you mean by a/c and heat are not working? Is the interior fan not pushing air through the vents?
Old Jun 22, 2022 | 12:14 PM
DJ1983's Avatar
No air coming through vents unless I’m going down the highway at 80 mph or so . (I can Thanks feel hot for code depending what it’s on
Old Jun 22, 2022 | 05:31 PM
Is the blower under the glove box not turning on and blowing air of any temperature through the vents?
Old Jun 22, 2022 | 10:01 PM
What trim level is this? You can check for HVAC trouble codes by following certain procedures with the HVAC controls depending on the type of system.
A dying or dead mode control motor may be the cause.
Old Jun 25, 2022 | 08:46 PM
DJ1983's Avatar
yes . I replaced it. I just replaced radiator fans to no prevail. I tested fans by connecting them to battery , both turned on with direct jump . But passenger did not come on without direct jump a cables to battery . Was told that mean fan needed replaced . Still won’t come on if I do not directly connect to battery. Wiring issue or something else
mirror
Apr 22, 2013 05:38 AM
tiledaddy
Mar 25, 2012 02:13 AM
poynterandy
Jul 24, 2011 07:33 AM
kendo
Oct 23, 2008 03:13 PM
Calevra18
Sep 22, 2007 11:41 PM
