Accord 1998 overheating
Old Feb 12, 2022 | 01:09 AM
Rilex's Avatar
Default Accord 1998 overheating
My accord 1998 is overheating but is not leaking any coolant. When the temperature rises I noticed there isn't anymore coolant in the radiator but the reservoir seems to overflow with coolants. The temperature rises when the car is driven around 20mins. What are the likely cause I hope is not a blown head gasket.I just installed a new transmission in the car. What are signs of blown head gasket. Hoping to hear from the forum soon. Thanks
Old Feb 12, 2022 | 10:12 AM
You'll need to troubleshoot.
Pressure testing the radiator can also identify an external leak in the cooling system which is easier to fix.
Fill up the radiator with the engine cold, with the radiator cap off, start up the engine. If you have a lot of gas bubbling out of the radiator, then you likely have a leak from the combustion chamber. It could be a crack in the cylinder head or the block cylinder, or a failed head gasket.
Rilex
Sep 3, 2015 02:59 PM
0pyders
Apr 3, 2011 03:12 PM
socalfornow
Nov 24, 2010 09:47 PM
Kreativ3z
Apr 7, 2010 01:59 AM
masterng
Aug 12, 2009 06:38 PM
