Accord 2.0 1988 LX, AT d3 & D4 gone out
Old Nov 30, 2014 | 09:29 AM
One Legged Eagle's Avatar
Unhappy Accord 2.0 1988 LX, AT d3 & D4 gone out
Hi all.
USA Accord 2.0 full AT LX mdl. 1988 carburator eng.
Suddenly, D3 & D4 combinatios, do not Works; stay into 1st and when wants to upchange, engine runs free, as clutch disengaged... Pos 2, and Reverse, working fine...Firmly and powerful... Clamp set in Parking, working intermitent, no path detected... Drained all AT liquid and refill with fresh correct liquid.- No solution. -gear 2 or R engaged, do not stall engine RPM;normal.
Of course I NEED SOME IDEA HELP...
Thanks in advance
One Legged Eagle (Really one legged old pilot)
Old Nov 30, 2014 | 10:34 AM
See attached chart of symtom to likely faults. Most or all are internal transmission faults that require removal/overhaul to address. Probably time to consider rebuild or replacement.
File Type: pdf
Old Dec 2, 2014 | 07:18 AM
Thank you very much.
May be there are F4 AT reconditioned or new?
>Thanks again
Old Dec 2, 2014 | 07:55 AM
I am sure your AT can be repaired, but finding a local repair shop w/ demonstrated track record, etc is your job. Finding a salvage on a vehicle this old is not a good bet,...likley to get something w/ problems as bad as yours!
There may be options to import a rebuilt AT, but shipping costs may be punitive.
good lukc
Old Dec 2, 2014 | 10:48 AM
Turtlehead's Avatar
Might want to try and pull the 3/4 shift solenoid and check the screen. Clean it and reinstall. Costs nothing to you if you are a DIY type of person and may solve the problem.
Old Dec 3, 2014 | 12:55 PM
Question
OK... thank you very much.
I'm asking:
Either way, must I remove the box and open it?
Old Dec 6, 2014 | 07:51 AM
The 3rd gens didn't use solenoids.
OP - based upon your location, finding a used trans might be harder than what most of us would find here in the states. As stated, you might call/search around for a shop with a good rating and see what they will charge to re-build yours.
Old Dec 17, 2014 | 01:11 PM
POORMAN212...Thank you very much...
As you said...That`s my possible way at this corner of the world.
Thanks again
raydavid93
Mar 16, 2013 09:23 AM
alyssapie
Aug 13, 2012 10:58 PM
drumdoctor
Jan 16, 2012 09:53 AM
powerpeecee
Jun 6, 2008 07:17 PM
gfavro@msn.com
May 5, 2006 07:58 PM
