accord 2000 2.0L ATF flush
Old Mar 26, 2018 | 08:37 AM
Eran Teitelbaum's Avatar
Default accord 2000 2.0L ATF flush
hello
i'd like to flush the fluid in the tranny, but the fluid is sold over here only in quarts, and since the manual says to flush 4 times it's gonna cost over $250!
so i thought to go the garage and have it sucked- is it allowed or possible?
thanks
Old Mar 26, 2018 | 09:01 AM
irhunter's Avatar
How many miles on the car? How has the AT been maintained up until this point?
My take is, the big risk of power flush is they almost always use some sort of universal fluid...not Honda-specific fluid. Hondas are notoriously sensitive to incorrect-fluid problems.
I like a simple drain/fill every 30k miles...using fluid from the dealer.
shipo's Avatar
Flush four times? Never heard that before, typically Honda/Acura folks do what is referred to as a 3x3 (drain/refill three quarts three times).
FWIW, I have an oil extractor which I use on my 2001 Accord 3.0 V6 transmission, because of obstructions in the transmission, I am only able to suck out two quarts at a time, so every 30,000 miles or so I do what I call a 2x2 (two quarts drained and refilled twice).
Regarding having a power flush done, do NOT do it; a dead transmission is an almost sure result of such a procedure.
Old Mar 26, 2018 | 09:53 AM
If you have it sucked out, that's about the same as what Shipo describes. That won't get the fluid to drain out of the torque converter, and therefore you only remove about 1/3 of the total fluid. That's the reason to drain/fill 3 or 4 times.
But that's only if the fluid has been allowed to get real dirty. If the fluid looks pretty clean on the dipstick, I'd just drain/fill it once, but drain it into a clean pan. Look at the fluid. Look for any sludge in the bottom of the pan. The only reason to do multiple drain/fill cycles is when you find crud coming out with the oil.
Then a reasonable thing is to drain/fill (once) every 30k miles or whatever interval results in the fluid draining out without too much crud.
Old Mar 26, 2018 | 10:55 AM
That's what i meant.
Old Mar 26, 2018 | 10:58 AM
shipo's Avatar
So nine quarts is going to cost you $250? Yikes!
To JimBlake's point, what color is the ATF currently in your transmission?
Old Mar 26, 2018 | 11:13 AM
I saw only the fluid that came out of the cooler lines when i removed the radiator and it looked red.
I just want it to have the original fluid.
Old Mar 26, 2018 | 11:48 AM
shipo's Avatar
What makes you think you don't have the correct fluid?
Old Mar 26, 2018 | 05:29 PM
i just wanna be on the safe side.
jkowtko
Sep 10, 2013 07:32 PM
Max Utility
Apr 16, 2012 04:47 PM
moey
May 22, 2011 10:43 AM
dtcaccord
Jun 4, 2008 09:54 PM
