Accord 2000 gear problem
Old Sep 15, 2010 | 01:13 AM
hac2000's Avatar
Default Accord 2000 gear problem
Hello, I had a problem with my car, when i start the car for the first gear it's ok, but when it shift to the second gear I feel jerks but if i move slow then there are negligible jerks but if i accelerate a little then i feel the jerk but only for the second gear the rest gears are ok, and by the way it's an automatic honda accord 2000 LX car.
Thanks in advance.
Old Sep 15, 2010 | 06:35 AM
Transmission fluid? Use Honda fluid & only drain/fill. Honda automatic doesn't like to be power-flushed.
Old Sep 15, 2010 | 07:06 AM
One minute before posting about a broken timing belt? What's the rest of the story?
Old Sep 15, 2010 | 08:21 PM
piggylover1985's Avatar
You could try pulling out the 2nd clutch pressure switch out and clean it to see if it will help, Should be green in color locates below the radiator hose in the back side, close to the fire wall and on top of the differential. Loosen it with a 22mm socket, try not to loose the washer behind the switch, as it's hard to find.
Old Sep 15, 2010 | 10:45 PM
deserthonda's Avatar
MMMMMMMM.......my thoughts exactly ..i hope that i am not walking close to a fish market ,,,
Honda had a lot of issues with trannies 98-02 ,sounds like the typical tranny issue , i would have it checked out by a shop ......any codes ???,, all motor mounts ok ?? tranny full of fluid ??
My man,, if you need a tranny and you also got possible engine issues from the other post ,, you might as well get rid of the car
letsclique
Jun 18, 2016 04:29 PM
d0n
Feb 4, 2013 08:45 AM
droidboy
Apr 3, 2012 02:43 AM
aznofthe205
Mar 15, 2009 04:25 PM
