Accord 2006 V6 AT issue
Old Dec 19, 2018 | 11:46 AM
ziggyMo's Avatar
Exclamation Accord 2006 V6 AT issue
I was driving on the high way at 80 m/hr and suddenly the car jerked and down shifted to 2nd and stuck on. CEL, D light and VSA light all came on blinking, swutched off the engine and started it again and I was able to drive for 3 mins without trouble the shifted normally and no blinking lights but then the same issue happened again.Parked at home I tried out a simple method to pull the codes by jumping the OBD 2 port using piece of wire. I got 2 codes from CEL and D light, one eaach.
CEL code 70
D light code 76
I had to change car battery and since then the codes disappeared but the car still jerks going into 2nd and 3rd gears and drives smoothly afterward, please help
Old Dec 19, 2018 | 03:02 PM
I wont be much help but I'm moving it to General Tech where more people will look at it.
The New-Member area is mostly for welcome & introductions. We don't really "forbid" newbies from posting in the tech areas.
Old Dec 19, 2018 | 03:32 PM
ziggyMo's Avatar
Thanks. Appreciate it. I'm desperate for help
Old Dec 19, 2018 | 08:39 PM
Stop by a parts store and have them scan the codes. Get the actual code number, like p1234 and post them on here. The 06 manual isn't matching the codes like you are posting.
Old Dec 20, 2018 | 03:30 AM
ziggyMo's Avatar
unfortunately, I had to replace the battery befor i could take it for a scan, there were no codes at all and I was told they were probably reset after replacement of the battery. The car works fine untill the gearbox warms up and the same issue happens again.
Milooo
Jan 26, 2023 06:09 PM
devinzmax
Oct 22, 2013 06:22 PM
elvis1977
Nov 2, 2012 06:42 PM
rjr8088
Mar 6, 2012 06:56 PM
explorer6380
Feb 26, 2007 03:44 PM
