Accord CD6 SiR - Hazards stuck on
Old Jan 23, 2012 | 10:32 PM
Archetype's Avatar
Default Accord CD6 SiR - Hazards stuck on
Accidently posted this in the wrong section before.
Hey there guys,
I'm going to be bidding on and hopefully winning an Accord SIR this Thursday. The only problem with it is the hazards are stuck on. What fuse would I pull so I can drive home without them being constantly lit up?
Will sort them out properly when I get home.
Also do you think 244,000 KM is too high for an H22A engine? The car looks in great condition cosmetically so hopefully this reflects the engine.
Old Jan 24, 2012 | 01:13 AM
I posted before, but it didn't show up.
You should get a buyer's inspection done on the car. If that isn't possible, ask the seller for documentation of the service done on the car. Look for spark plugs, oil changes, timing belt.
This is a non-US accord, so what year are you buying?
244,000 km (150k miles) is not high mileage if the car was well maintained. My 95 accord had 250k miles on it when I sold it.
Old Jan 24, 2012 | 01:14 AM
Also, there should be a fuse for the hazard lights. Take a look at the owner's manual. If the hazard switch is stuck, your turn signals will not work.
Old Jan 24, 2012 | 02:07 AM
Archetype's Avatar
It's from Japan, I'm in New Zealand and we're RHD
I don't mind about the signals, they wont work anyway if the hazards are stuck on, I will just use hand signals and drive extra slow.
There has been a visual inspection done and also a driving inspection, this is from a company that usually deal with repo'd cars so they're not original owners, hence why it's going for quite cheap. I'm going to check under the oil cap at the condition of the rockers etc... that's a pretty good way to check high mileage engines. Will also take it out for a test drive to see if I think everything is fine.
This is the report : http://www.turners.co.nz/Vehicle%20C...&GoodNo=970788
I don't care about the A/C as I never use it and will end up pulling it out anyway.
Old Jan 24, 2012 | 06:09 PM
What happens/try prying out the hazzard switch and unplug it?
EDIT:...I now see Jim was already suggeting the switch being stuck. Sorry.
specialops
Mar 23, 2013 01:12 PM
Archetype
Jan 27, 2012 12:46 PM
midnightblade
Oct 27, 2011 10:55 PM
Turbo_Accord_2010
May 23, 2010 01:15 PM
wsbowen03
Apr 30, 2009 02:46 PM
