Accord Cold Start Problem
Old Jan 6, 2011 | 06:20 AM
Garp242's Avatar
Default Accord Cold Start Problem
1999 Rover 620 (Honda 2litre engine, petrol)
Hi All ... What I thought to be "dampness in cylinders" in a previous post, has now become a little clearer ...
The symptoms are pretty straight-forward ... the car will not start when cold.
If I remove the plugs, heat them with a gas torch and refit ... starts first time and will run perfectly until the engine cools down again, then I have to repeat the process ...
I've followed the procedure for accessing the Fault Codes ( linking diagnostic socket with a paper clip) but no faults are registered.
Any ideas greatly appreciated ...
Old Jan 6, 2011 | 07:11 AM
Tried brand-new plugs? Sounds like maybe insulator is cracked, or tracked, allowing spark to short to ground. When warmed up & dried off thoroughly, the short is gone. I had a similar problem with distributor cap. Tracks etched into the surface would short the spark only when the cap was cold & damp. They looked like microscopic scratches.
Old Jan 7, 2011 | 09:59 AM
Garp242's Avatar
Hi Jim
Your advice seemed to make sense, so I found an old set of plugs in my toolbox, (that had been removed at last service), cleaned them up, and thought I'd give it a try ...
Started first turn of the key !!!
Lesson learned ... never overlook the simple things !!
Many thanks for the information ... will treat my "pride & joy" to a new set of plugs tomorrow ...
justmeedp@cox.net
Oct 5, 2014 08:14 AM
gasface11
Jul 11, 2012 12:33 PM
Mimez
Apr 5, 2012 05:59 AM
mannonline
Nov 26, 2007 02:57 PM
skareb
Dec 4, 2006 08:20 PM
