cold start carb problem
Old Nov 25, 2007 | 08:27 PM
mannonline
Default cold start carb problem
Please help. 1988 carb accord 5 speed manual.
I first noticed oddly high idle speeds (about 2500). That went on-and-off for about 2 weeks. Now when I start the car it dies. I have to play with the gas to keep it running long enough to get hot. After it warms up-it runs and idles fine. Any Ideas.
Thanks
Mike
Old Nov 25, 2007 | 09:11 PM
Default RE: cold start carb problem
High idle speeds when cold along with normal idle when warm points to a fast idle valve problem.
Here is a thread that has some pics and links that you might want to try. It was an 86 accord, so yours should have a similar setup since they are the same generation.
https://www.hondaaccordforum.com/m_85747/tm.htm
Old Nov 25, 2007 | 09:26 PM
mannonline
Just to be clear:
My Accord is a carb (none injected) does it still have a bypass valve?
thanks,
mike
Old Nov 25, 2007 | 10:44 PM
I should have read your car more carefully. I don't think that an accord with a carb has those air control valves. I am not familiar with carbs at all, so someone else might be able to help you on here.
I know that there are posts on carb/idle issues, so you might want to use the search function.
Old Nov 26, 2007 | 02:57 PM
sir_nasty's Avatar
I had a similar issue with my 81 civic and with idle issues and carb's it can be a lot of things, Honestly, I just ran a bottle of gum-out carb cleaner through the tank and it smoothed it out considerably.
Something to try that's quick and easy
biggame
Jul 30, 2012 09:31 PM
gasface11
Jul 11, 2012 12:33 PM
ris3nda3mon
Jul 17, 2010 10:12 PM
p89
Aug 5, 2005 10:29 PM
Alekat
Jun 22, 2005 08:47 PM
