Vacuum controlled problem, (carb thermovalve/power valve)?
Old Jun 22, 2005 | 08:47 PM
Alekat's Avatar
Default Vacuum controlled problem, (carb thermovalve/power valve)?
Have an at operating temperature condition on an '87 carb'd LX auto where the vehicle will act as though the ignition switch is being shut off and back on in a fraction of a second when the engine reaches a shift point and the vacuum is at peak. Frequently there is a feel of a slight hesitation/stumbling during acceleration The vehicle runs perfect when cold, (under 165 deg), and idles fine at operating temp.
Have replaced a frequency control valve and anti-afterburn valve, (there are a number of these). Removed, cleaned and tested the EGR valve.
Am considering a replacement carb since some symptoms point to a defective power valve/circuit, (not the power piston), and is vacuum controlled.
Any thoughts - Anyone?
88accord
Nov 1, 2011 10:10 AM
tycobb280
Apr 16, 2010 09:34 PM
Milanodan
Jan 21, 2010 03:55 PM
Rainy
Sep 29, 2009 05:26 PM
PHtrump3
Jul 28, 2008 10:01 PM
