Accord Engine Damper
Old Sep 5, 2012 | 09:14 PM
Swinnyp's Avatar
Default Accord Engine Damper
I have a 99 Accord that had a damper fail. Belts came off, immediately pulled off road. mechnanic says that I need timing done and new timing belt. do I really need timing work?
Old Sep 6, 2012 | 05:53 AM
Do you mean the crankshaft pulley/Harmonic Balancer failed? How? pulley separated from rubber bushing?
If crankshaft bolt remained in place and timing belt covers are intact, no harm to timing belt should have occurred.
You can install a new harmonic balancer/pulley and align crankshaft and camshaft timing marks manually to check proper engine timing. If Ok, I would not replace timing belts, ...unless they are due soon (< 10K miles) anyway.
baconsum1
Dec 12, 2008 02:22 PM
honda97acc
Jun 15, 2008 03:29 PM
ziwang55
Jun 4, 2008 12:22 PM
falkore24
Oct 23, 2007 11:28 AM
tsblckcord
Feb 22, 2006 07:07 PM
