Accord Locked Out!
Old Jun 1, 2008 | 02:42 PM
Accord Owner's Avatar
Default Accord Locked Out!
I left the keys inside so I called Triple AAA and they were able to put some high tech tools through the window and open my car, the tool looked like a blood pressure test system. Anyone know what that is?
Old Jun 1, 2008 | 03:29 PM
finch13's Avatar
Default RE: Accord Locked Out!
They didn't use a good ol' slim jim?
Old Jun 1, 2008 | 04:06 PM
YeuEmMaiMai's Avatar
they used an air bladder to pry the door open at the top so they could insert a tool to hit the power lock button. most places do not use slim jims anymore becuase if the liability issues involved (busted power locks)
Old Jun 1, 2008 | 05:09 PM
ORIGINAL: finch13
I think thats what he used, he stuck it through the hole and opened the car
Old Jun 1, 2008 | 05:10 PM
ORIGINAL: YeuEmMaiMai
aha...so what does the air bladder actually do? it was amazing...........it did not damage
Old Jun 1, 2008 | 06:16 PM
It basically pryed the door away from the frame to open a gap to insert that tool in there.
Old Jun 2, 2008 | 06:49 PM
ORIGINAL: PAhonda
what does that do, pressure on windows? possible damage?
Old Jun 2, 2008 | 06:57 PM
It distributes the force over a wider span than a crowbar would, so there is no damage due to blunt force in one area.
Old Jun 2, 2008 | 07:12 PM
ORIGINAL: PAhonda
Wow, I could not understand that.
Can you explain in simple English?
Old Jun 2, 2008 | 09:17 PM
gomarlins3's Avatar
Hide-a-key in a velcroed pouch on the car is an easy solution for the next time.
This is actually a concern of mine. On the newer Honda's, when you press 'unlock' on the remote and you do not open the door within 30 seconds, the doors relock. Even if you open the trunk, the doors will still relock. If for some reason you put something in the trunk and place your keys in there without thinking (maybe in the pocket of your jacket when you put your jacket in the trunk) and the doors relock, you are locked out of the car when you close the trunk. I went to Honda today to see if it can be changed and they said it could not. Their suggestion was a hide-a-key, and use your valet key. You need to use a velcroed version because the others are held onto the car with a magnet and our newer keys can not be near magnets. Besides, there are not many spots on the car that are easily accessable and are metal any more.
teemo
Jul 11, 2013 07:15 PM
SirJohnIII
Dec 13, 2010 01:32 PM
anhaedra
Dec 28, 2007 10:20 PM
RR_Rex
Oct 19, 2007 01:03 PM
Trey1010
Apr 2, 2007 12:12 AM
