accord type r distributor replacement timing?
Old Jan 22, 2014 | 04:22 AM
madmaz460's Avatar
Default accord type r distributor replacement timing?
Hi ive recently purchased another distributor for my 99 accord type r, just wondering whether I will need a strobe to set it up? Or is it fixed? Cheers, Mario
Old Jan 22, 2014 | 06:51 AM
Where are you located? Type-R isn't a USA car, so there might be some differences.
USA Accords timing is controlled by a sensor at the crankshaft pulley, and the distributor mounting doesn't have any slots in the mounting holes. Even if you were to grind out those mounting holes, elongating them into slots for adjustment, it won't change the actual spark timing.
In England, for example, the saloon cars (built in Swindon) are completely different cars from USA sedans. But the coupes (2-door) are the same as USA. So it helps to know what kind of car you're talking about.
Old Jan 22, 2014 | 07:29 AM
madmaz460's Avatar
I am in the uk, it is a uk car. The distributor has 1 hole and 2 slots.
Old Jan 22, 2014 | 11:31 AM
I think(?) UK is the same, so if you have a timing light you can CHECK the spark timing. But you can't adjust it.
Pir8Darryl
Nov 11, 2013 11:55 AM
donjuanlucas01
Feb 17, 2013 09:10 PM
jdmjnky
Sep 21, 2010 11:21 AM
jq_quint
Oct 12, 2009 02:49 PM
Pacmanpth
Sep 9, 2007 11:43 PM
