Adding a/c Oil
Old Jun 9, 2007 | 06:51 PM
sbclemens's Avatar
Default Adding a/c Oil
This is my first time working on an A/C system so I decided to replace the condenser, evaporator, and he receiver/dryer. The condenser and evaporator had major leaks.Since I've gone this far, I'll also be converting to134A. The service manual says to add certain amounts of oil when replacing various components. Now the dumb question is do I add the oil to the various parts or just to the compressor?
Thanks
Old Jun 9, 2007 | 10:09 PM
hondadude's Avatar
Default RE: Adding a/c Oil
add the oil thru the low side port after you have it under vacum
Old Jun 11, 2007 | 08:41 AM
The oil distributes itself around as the AC runs. That table is based on how much oil ends up in each component.
If you're converting from R-12 to R-134a, I think you'll have to drain the old oil out of the compressor. And possibly any other components you don't replace.
moey
Aug 9, 2014 06:53 PM
MiyashiMeism
Sep 5, 2010 02:12 PM
soulbrother2002
Feb 15, 2006 12:46 AM
tcodi
Nov 22, 2005 12:45 PM
g6ex6
Apr 6, 2005 08:10 PM
