adjusting air mix cable/blender door
Old Jul 28, 2011 | 04:37 PM
Tek310's Avatar
Originally Posted by PAhonda
Here are is the vent temperature, low psi, and high psi assuming it is 95 degrees outside with 80% humidity at 1500 rpm. This is from eyeballing that chart:
Vent 70 degrees.
Low 52 psi
High 380
Assuming it is 95 with 30 % humidity:
Temp at vent 57
Low 40 psi
High 300 psi
Okay so those pressure readings should be read at 1500rpm and not idl?e
Old Jul 29, 2011 | 01:23 AM
That is from the 94 shop manual that you can download from the online manuals link in the General DIY thread. It says to run the test at 1500 rpm for ten minutes, then take the reading. Take a look at the instructions on how to test.
Old Jul 29, 2011 | 07:46 AM
Tek310's Avatar
I have that shop manual as well as ALLDATA at school. It just confuses me.
I'm guessing you spin the engine at 1500 for 10 mins then let it idle and check the pressure then.
Thanks..
pr1madona
Feb 23, 2014 11:26 AM
tmarch
Dec 27, 2012 03:53 PM
Tradewind
Aug 4, 2012 11:37 AM
blutarsky
Nov 20, 2011 04:52 PM
drlemon
Oct 7, 2010 03:48 PM
