Adjusting the timing
Old Oct 22, 2011 | 07:53 AM
Drake75's Avatar
Default Adjusting the timing
I have a 1994 Accord and i need to adjust the timing. Is there an easy way to do this without removing the top timing cover?
Old Oct 22, 2011 | 09:14 AM
Not sure what you are needing...it is early for me.
Timing can be adjusted slighly using the distributor, be sure to follow the proper procedure.
IF you think the belt is off a tooth (or more) then the only way to check is by pulling the upper cover (not really that hard to pull just the upper part - 2 maybe 3 screws?). Frm there set cyl#1 to TDC and check the marks.
Old Oct 22, 2011 | 10:15 AM
On 94 Accord igntion timing is adjusted w/ engine idling, service check connector shorted, and setting red timing mark (loosen distributor bolts and adjust distributor) on crankshaft pulley to align w/ pointer on lower timing belt cover.
Perform engine timing check as PM indicated.
Old Dec 21, 2011 | 01:22 PM
6-Speed's Avatar
Is it necessary to re-adjust engine timing after removing and replacing the distributor assembly to change the O-ring? It's a 97 Honda Accord - 4 cylinder non-VTEC engine.
Old Dec 21, 2011 | 04:45 PM
If you mark the distributor-bracket position w/ black mark, you can return to same position and avoid tiiming adjustment.
I'm not sure if 97 requires any adjustment as the timing is completely controlled by ECM w/ separate TDC sensor.
Pattywagon
Aug 4, 2012 01:44 PM
kegwad
Jun 22, 2009 09:20 AM
kbrown@insystcom.com
Feb 27, 2007 05:07 PM
dave118811
Dec 17, 2006 06:08 AM
shaleck
Oct 20, 2006 08:25 PM
