Aftermarket Keyless Entry
Old Apr 2, 2016 | 01:31 AM
TexomaAccord's Avatar
Default Aftermarket Keyless Entry
1997 4 door accord lx -- already has power door locks.. So I bought a cheapo keyless entry, these are my instructions..
I did find this link 1997-*Honda*Accord*Vehicle Wiring Chart and Diagram
But I'm still lost on what goes where.. Any help?
Attached Thumbnails Aftermarket Keyless Entry-cr27-b.jpg   Aftermarket Keyless Entry-cr27-.jpg
Old Apr 2, 2016 | 07:55 AM
If my failing memory serve me......there should be a two wire "plug" near the under dash fuse panel that isn't plugged into anything.
This plug is a "tap" into the door locks......from the factory they had this connection for either a dealer installed system or factory.
The locks are a "negative trigger" via the control module in the drivers door.
Old Apr 2, 2016 | 12:52 PM
See this thread, which is similar:
https://www.hondaaccordforum.com/for...on-help-56065/
Old Apr 2, 2016 | 06:31 PM
Ok, so I found a 3 wire plug wrapped in blue tape. One wire is orange, another black/white, another yellow/red.
So my understanding is my white wire goes to orange, and my white/black goes to black/white?
Old Apr 2, 2016 | 06:50 PM
No, based on your keyless system diagram the White wire (close) should go to the car's Blk/Wht wire(lock input).
The keyless system Wht/Blk wire (open) should go to the car's Orn wire (unlock input).
Old Apr 2, 2016 | 07:05 PM
Okay, thanks.. Gonna go unhook the one I put in already lol --- Man, my back is gonna be killing me after this.. Very difficult, those wires on the connector dont give you any room to pull them down
Old Apr 2, 2016 | 07:25 PM
I hooked it up. It has power, grounded good.. For the life of me, I can't get it to lock/unlock (with doors open/closed) Remote lights up, control box clicks.. I pushed the code learn and push unlock, and do it for lock.. and nada
Old Apr 2, 2016 | 08:21 PM
Check/Re-check that the keyless system's Yellow wire and Yel/Blk wire are both grounded.
If they are, try switching the connections of the system's lock and unlock wires. The keyless system's diagram may be mislabeled.
Old Apr 2, 2016 | 09:12 PM
Ok, so... I had used all those blue snap connectors, and well apparently none of them were worth a flip, so I stripped the wires to make bare wire connections, and now it works! -- Ugh.. Thank you both.. I WAS going to make a video, good thing I didn't.. Would be full of bleeps.. I may go ahead and make one, showing where the wires are and all that jazz.
Mstrmonkyman
Feb 2, 2017 09:48 AM
Ojie
Feb 24, 2014 12:28 PM
dls725
Sep 16, 2008 11:16 AM
IUHooshur
Jan 4, 2006 12:04 PM
