Air compressor help
Old Jul 8, 2014 | 03:56 PM
jroxz44's Avatar
Almost A Senior Member
Default Air compressor help
I have a 1995 honda accord 2.2 vtec automatic. And I recently decided to charge my A/C for the summer. I've had the car for 4 years now and never had it charged.
I bought the can ,hooked it up , turned my AC on and the car shut off.
I started it back up and kept it running while the freon went into the compressor and I saw smoke coming from the compressor. I shut the car back off and the AC pull was extremely hot. I started the car back up and left the AC off and the car ran fine as soon as I turn the AC button back on the car dies and the pump starts smoking. Sometimes the car stays running but the idle loops up and down
I need to know what is wrong and if it's an easy fix or what are my options. Should I just turn it on and keep the car running or is this a major issue. I didn't know cause it hasn't been charged in a very long time. If it needs kinda broke in
Also if it's broke completely can I buy a drive belt to bypass the AC completly. Just for the crank and alternator. If so where's a good place to pick that up
Old Jul 8, 2014 | 05:21 PM
I'm no AC guru so I'll just ask for the benefit of those who DO know something...
Why did you think it needed to be charged? Was it not cooling? Was the compressor running but not cooling? Did you measure high & low side pressures when it was running? Just some background to help us understand what led you to this point.
Old Jul 8, 2014 | 09:42 PM
jroxz44's Avatar
I've never had cold air in the car since I bought it 4 years ago. And this year has been extra hot where I live. So I got a can to recharge it. The guy I bought it off of said that it worked before just needed charged. And I don't know what you mean by checking the pressure. I can pretty much do any work on the car but I've never messed with the air conditioning in any vehicle I've owned.
As soon as the compressor kicks on the car wants to stall out. And the pully begins to smoke and get hot
Old Jul 8, 2014 | 10:16 PM
Sounds like a seized compressor.
There is an Accord DX alternator belt w/o A/C available if you wanted to bypass the compressor.
Old Jul 9, 2014 | 07:16 AM
jroxz44's Avatar
When i turn it back off the car runs fine. But I'm just gonna try to bypass it completly incase it seizes up completely and leaves me stranded
Old Jul 9, 2014 | 01:36 PM
Turtlehead's Avatar
With the car off see if the clutch plate spins freely. If not just get a used one. Oddly enough I have a 95 good compressor from an LX that I saw in the back of my shop today.
I would never add R134a the way you did. You really need to know the science behind the high pressure and low pressure, relative humidity when adding, and ambient air temperature at the time you are adding.
ak474u
May 4, 2015 11:15 PM
dawgs2269
Jul 26, 2011 12:01 PM
JDennis928
Jul 5, 2011 08:02 PM
Johnene
Aug 15, 2009 01:13 PM
ricj
Jul 15, 2007 09:07 PM
