Air Filter Install
Old Mar 7, 2007 | 05:52 PM
mrmookie123's Avatar
Default Air Filter Install
Good Afternoon Everyone, Hope your all doing well.
I installed a new K&N air filter. With these new computerized engines, Do I need
to do anything about resetting the computer to know about the new air filter, I've
read that you should disconnect the Negative battery cable for awhile so that things
reset and the system will adjust to the new air flow. I didn't do it, but thought I'd check
to see if I can get some input on whether or not I should do this.
Thanks for any replys.
Old Mar 7, 2007 | 06:21 PM
HondaRacer4Vtec's Avatar
Default RE: Air Filter Install
Its always a good idea to reset ECU after you put in new mods. All you have to do is unplug negative battery for like 5 mintes. then start the car till its get to normal operatingtemperture.
Old Mar 7, 2007 | 08:07 PM
Another thing since you got a K&N... Check whether you have an air-flow sensor in the airfilter housing (I'm guessing yes). If you do, then it's important you don't over-oil the filter so you don't get oil all over that sensor.
Old Mar 7, 2007 | 10:04 PM
deserthonda's Avatar
also if you disconnect the battery cable , and you have anti-theft stereo , make sure you have the code before disconnecting the battery
Old Mar 8, 2007 | 01:34 AM
Thanks for the replies. JimBlake, thanks I'll remember that down the road when I clean and re-oil the K & N filter. Deserthonda, No anti-theft stero but thanks for the information. As always, thanks for the information, very much appreciated.
Special_K
Aug 12, 2011 04:16 PM
bjr001
Mar 5, 2010 07:31 PM
Daveyjones
May 29, 2006 04:40 PM
TucsonBob
Feb 26, 2006 04:40 PM
alabamatoy
Jan 24, 2006 10:17 PM
