Air mix motor?
Old Nov 15, 2016 | 10:54 AM
handirifle's Avatar
Default Air mix motor?
Greetings to all. New here, but not new to auto repair. I do all my own maintenance, except timing belt, on our 2005 Accord EX, V6, with a little over 205,000 on the clock.
I did a search looking for air mix motor and couple other terms with no luck, so here goes. On the drivers side, when car is running is sounds like a mouse is running around in the dash, drivers side. AC works fine, but temp control seems like sometimes it keeps temp fine, sometimes not.
From what I can tell with internet search, it is the "air mix motor"? But as I search I see some comments that it is on the pass side, some on drivers side. I THOUGHT it was on DS, but now I am not sure.
Also looking at parts online, prices vary from about $75 to $150. Best source to get it?
Thanks for any help you can give.
Old Nov 16, 2016 | 08:54 AM
Here's the shop manual diagram.
Any OEM Honda parts outlet will have same part. Only price will differentiate.
File Type: pdf
Old Jul 27, 2017 | 04:22 PM
dcpappas1965's Avatar
Default Air Mix Motor / Motor Assy, Temperature Driver
TexasHonda,
Please share the air mix motor Replacement Procedure (if possible). I'm planning on replacing one on my 2006 Accord Ex V6 Automatic 4 door.
I believe the part number is 79160-SDA-A41 but I'm not certain. It'd be great if you can also confirm that number for me.
Thank you for any help that you can provide.
Old Jul 27, 2017 | 05:12 PM
See attached. It may not cover access issues which can be painful, but should be doable.
Old Jul 27, 2017 | 09:34 PM
TexasHonda,
Thank you for the quick reply and for the replacement procedure. Much appreciated.
Old Aug 1, 2017 | 10:03 AM
CHUCKW's Avatar
I just handled this same problem. You can find videos on youtube about this. Your part number is right and I got my replacement motor from Hondapartsnow.com. I believe it was about $74-75. Look for my thread in this forum called "tapping in driver's side dash" or something like that. I posted the youtube video. Also, when you get under the driver's side dash to get at it, it is in a terrible position, you'll see a bracket between the firewall and dash that you should remove to make it easier to replace the motor.
Old Aug 3, 2017 | 12:00 PM
oldbeek's Avatar
Watched video. Did it myself with poor close vision and 75 yrs old. You can do it in 2 hrs easy.
Old Aug 10, 2017 | 11:59 AM
Default Top Screw Access for Air Mix Motor / Temperature Driver Part # 79160-SDA-A41
CHUCKW, Thank you for Confirming the part number.
Here's how I got to that top screw (2 pics attached) without removing the metal bracket that was mentioned. I hope these pics help the next person trying to do this job.
Old Oct 26, 2024 | 01:29 PM
Mward008's Avatar
Default need 2005 honda accord coupe air mix motor test
View the attached pdf. Do you mind sending me the air mix control motor test procedure on page 21 - 43 for the 2005 accord EX coupe?
File Type: pdf
LordLivingston
Apr 26, 2016 10:23 PM
tmarch
Dec 27, 2012 03:53 PM
Tradewind
Aug 4, 2012 11:37 AM
blutarsky
Nov 20, 2011 04:52 PM
Tek310
Jul 29, 2011 07:46 AM
