alternator belt
Old Dec 14, 2006 | 01:37 PM
kcobra
Default alternator belt
how do you remove the tension on the alternator belt so a new one can be installed 93 accord
Old Dec 14, 2006 | 03:40 PM
deserthonda's Avatar
Default RE: alternator belt
first of all..you need to loosen up the top and bottom alt bolts ,, top is 14 mm head. bottom is 12 mm head,once loose , looking from the frt of the car , below alternator there is a 10mm head bolt that you have to loosen up ) do not remove it ) .. that bolt is the belt tensioner adjustment // loosen it enough to remove the belt.......instal new belt ,, adjust properly and tighten all the bolts ..
mikek
Aug 6, 2019 07:37 AM
Imonlybonnie
Nov 18, 2013 11:48 AM
aking
Apr 4, 2011 11:19 AM
jenny
Oct 17, 2008 04:23 PM
JKobielusz
Aug 6, 2008 06:50 PM
