Alternator belt slipping
Old Mar 7, 2013 | 07:02 AM
batout's Avatar
Default Alternator belt slipping
I have a Honda Accord Automatic Hatchback.However the Mechanic who fitted my new alternator seemingly has not done the job properly,the alternator belt keeps slipping,and the nut which holds the belt is not sufficient to keep the hold on. I cant find a mobile mechanic in my area nor garage which do callouts. So literally stuck.I can see it looks a simple job,but know zero about cars,any help or pointers woul be gratefully received.The battery and alternator are fine.
Best regards
Old Mar 7, 2013 | 07:43 AM
Well, it's difficult to help if we don't know what year/model/engine you have.
It's common for new belts to stretch a bit, but if he put the old belt back on maybe it's hard & slippery from age & heat.
Old Mar 7, 2013 | 10:02 AM
batout's Avatar
It is an Accord 1.8i year 2000.the belt seems fine looks new,but the nut holding the belt keeps loosening.
Old Mar 7, 2013 | 11:14 AM
That combination of year & engine sounds like Europe or UK?? It's a different car, but probably the alternator & belts are about the same.
What comes loose exactly? You have to tighten #6 & #10 as well. The #5 bolt is just to pull the alternator out for tensioning.
Attached Thumbnails Alternator belt slipping-2000-4cyl-alternator-bracket.jpg
mikek
Aug 6, 2019 07:37 AM
Imonlybonnie
Nov 18, 2013 11:48 AM
aking
Apr 4, 2011 11:19 AM
kris_loehr
Dec 16, 2009 07:17 AM
kcobra
Dec 14, 2006 03:40 PM
