Alternator replaced..but with side effects
Old May 19, 2014 | 11:53 PM
My opinion is that is related to the alternator. The battery light on the dash usually indicates a problem with the charging system, not really the battery.
Some Delphi alternators were known to have a host of problems such as bad bearings, diode, overheating, etc. You may have a charging problem that is causing the other electrical gremlins.
Old May 20, 2014 | 03:04 AM
gary85_'s Avatar
I appreciate your response. Guess i'm gonna send the new altenator back and spend the extra money and buy local.
Old May 20, 2014 | 10:56 AM
Check that B+ connection to alternator is secure.
Also check the crankshaft pulley rubber bushing for slippage. This can produce maddening intermittent problems. Outer pulley slips on rubber bushing and reduces charge level which could set off charge lights and other faults (low voltage).
Check for wobbling pulley and also make a radial mark across pulley bushing, and inner drive core. If radial mark separates you have a problem.
Old May 21, 2014 | 02:45 PM
holmesnmanny's Avatar
your results are normal ... alternators start making peak power at 1500+ ... doesnt look like anything wrong with that alternator ... most driving will be at 1500+ so there will always be enough charging of the battery
also honda charging have two modes .. low and high after the car has warmed up so sometimes it will charge at 12.70 or so to save gas when there are no loads and ac is off
Old May 21, 2014 | 06:10 PM
gary85_'s Avatar
Replaced with another new one from napa, it is 110 amps. took for short test drive and so far so good. will post again in a week to keep folks updated if this was the actual fix.
Old May 27, 2014 | 05:21 PM
gary85_'s Avatar
Wanted to update, everything still good with napa alternator. Just a reminder, even though you buy a new alternator, doesn't mean it's gonna work perfectly. Make sure to keep your receipt.
Old May 27, 2014 | 05:25 PM
  #17
Good to hear. Thanks for reporting back the resolution.
Orionis
Jun 9, 2008 02:29 AM
BlueByYou
Oct 8, 2007 12:42 PM
98Accord220HP
Jul 4, 2006 10:16 PM
sTeVo!
May 21, 2006 04:58 PM
theycallmerickjames
Oct 10, 2005 03:00 PM
