Am I testing this egr solonoid correctly?
Old Feb 15, 2013 | 01:45 PM
Did you tee the EGR actuation vacuum line to monitor vacuum or hook directly to vacuum supply to the EGR valve?
System monitors EGR vacuum and will likely react differently if the vacuum supply is not connected to EGR valve. System modulates EGR vacuum solenoid on/off/on... to obtain a certain change in manifold pressure.
Old Feb 15, 2013 | 05:56 PM
draser's Avatar
I'm trying to understand your set-up, since on my '99 the EGR is mounted on the intake mani and there's a exhaust port going into it. The ECU controls opening and closing it.
Where is yours installed? You said you have a vac line from the intake plugging into it? How does it connect to the exhaust?
bigblock67
Nov 27, 2012 05:39 PM
bnwbass
May 5, 2012 06:41 PM
IntoTheGround
Dec 10, 2009 02:24 PM
AccordLXMaster
Dec 8, 2008 03:39 PM
squeek
Jun 27, 2008 07:20 PM
