Another AC problem, 97 LX 2.2
Old Jul 2, 2011 | 06:38 PM
  #21
Have you checked fuse 8 in under-dash fuse box? This provides power to the ac compressor relay and on to compressor.
If you confirm power to the ac relay through fuse 8, then ECU is only thing that could prevent compressor from engaging.
Since both cooling fans are engaging, this indicates the ground path through AC switch and blower switch is good. This should tell ECU to enable compressor. If ECU is not providing ground, it may be damaged, even though car starts fine.
campy19@optonline.ne
Apr 18, 2014 12:31 PM
HondaAccordKid
Oct 28, 2010 11:32 AM
silver03
Dec 27, 2007 07:31 PM
sdadd
Aug 25, 2006 12:14 AM
greaser
Aug 24, 2005 12:01 AM
