any 96 ex owners, i need your help! small vac line?
Old May 18, 2012 | 04:48 PM
firefighter44's Avatar
Almost A Senior Member
Default any 96 ex owners, i need your help! small vac line?
I noticed a loss of power the other day and decided today to change spark plugs, replace the air filter, and clean the throttle body. while doing this i replaced a couple vac lines and found this its sitting under my air intake and not bolted in its correct spot and this line is hanging open any one that has a 96 ex or knows a good bit about them i need to know where this bolts at and where this line is supposed to connect. I have a feeling that it has something to to do with the air intake as it has been replaced with a cai. any help would be much appreciated. here are pics of the hose and the "f" shaped "tee"
Old May 18, 2012 | 05:10 PM
crispin's Avatar
looks like a small square to me
Not sure where that goes
Old May 18, 2012 | 05:16 PM
one end is square and has these small vac lines coming off and the other end has an electrical connector ill try and shoot a closer pic real quick and post it here momentarily.
ok here is a somewhat better(closer with more detail) pic
Old May 18, 2012 | 05:39 PM
Same pic with color coded labels to help figure out what your looking at
Old May 18, 2012 | 05:51 PM
crispin's Avatar
I can see the pics now
What you need to do is take a picture from further away.
Everyone always takes them real up close but without the far away pictures we cannot get any bearing to where the item is.
Old May 18, 2012 | 07:52 PM
Intake Air Resonator (IAR) Control Solenoid Valve, which was previously mounted on Resonator Chamber B (Part # 3 in first picture, which was probably removed).
See attached pics.
Attached Thumbnails any 96 ex owners, i need your help! small vac line?-iar-control-solenoid-valve.jpg   any 96 ex owners, i need your help! small vac line?-vacuum-lines.jpg   any 96 ex owners, i need your help! small vac line?-iar-valve-location.jpg   any 96 ex owners, i need your help! small vac line?-iar-system.jpg   any 96 ex owners, i need your help! small vac line?-iar-valve-pic-2.jpg
Old May 18, 2012 | 11:46 PM
so whats my best option here, just let it continue to sit there under the cai and plug that open line? I know it still receiving vac pressure because i could feel it when i stuck my finger over it. I have it plugged at the moment, so again is this my best option?
Old May 19, 2012 | 05:54 AM
crispin's Avatar
Yes plug the line.
It is a shame that it wasn't plugged when the CAI was installed as it allowed unmetered air
into the motor which makes it run bad.
This is why it is always preferred to buy a car that is all stock and hasn't been modified.
Old May 19, 2012 | 12:56 PM
Originally Posted by crispin
Yes plug the line.
strange enough when i bought it it ran great then just recently its had a loss of power, i changed the spark plugs, put on a new air filter, cleaned the throttle body and plugged that line and it seems to be doing better.
eduard
May 9, 2013 12:11 AM
99GrandPrix
Apr 6, 2012 07:08 PM
PhilipK
Oct 31, 2007 08:28 PM
Tube_sox
May 5, 2007 11:27 AM
90JDMACCORD
Oct 18, 2004 04:05 AM
