ATF. Dex II = Castrol Import Multi Vehicle?
Old Mar 21, 2009 | 04:19 PM
H8FWD
Default ATF. Dex II = Castrol Import Multi Vehicle?
Hi, I just inherited a 1991 Accord.
The manual calls for Dexron II ATF. It seems that no one makes anything labeled as Dexron II anymore. Will Castrol's Import Multi Vehicle ATF work?
Thanks.
Old Mar 21, 2009 | 04:34 PM
finch13's Avatar
It should. The ratings are kind of like brake fluid... if they don't have DOT 3, you can use DOT 4, if they don't have Dex II, you can use Dex III. I'd personally put Honda ATF-Z1 in it, but I think Castrol would be okay.
96cord
Aug 4, 2012 11:18 PM
letsclique
Jun 11, 2012 09:14 PM
moey
May 22, 2011 10:43 AM
coup de grace
May 29, 2008 04:44 PM
