Auto AC Pressure
Old Apr 25, 2012 | 07:38 PM
curtie94's Avatar
ok ya I can get a used compressor from my junkyard for $40. I just went and looked at the whole system again and noticed a faint green on the condenser bottom right corner.
Old Apr 26, 2012 | 07:30 PM
Bottom right ? (pass side?). I think you replaced the o-rings already, so do you think this could be a break/leak in the condenser?
If so, might as well see if you can get one of those as well.
Old Apr 26, 2012 | 09:18 PM
curtie94's Avatar
Ya I was looking at the condenser with a black light while running the ac and I could see the uv dye bubbling out of the bottom drivers side of the condenser. I did replace the o-rings, but it is the condenser. My Junk yard does not have a condenser.
I could also see uv dye/refrigerant leak out of the compressor.
It is cool when you can actually see it.
Old Apr 27, 2012 | 11:49 AM
check ebay for reasonable new and used. car-part.com may be able to locate a used unit near your zip code.
eduard
May 9, 2013 12:11 AM
SwitchUps
Oct 21, 2010 05:37 PM
piconrule
Jul 24, 2009 02:38 PM
dejavu247
Dec 4, 2006 07:50 PM
tcodi
Nov 22, 2005 12:45 PM
