Automatic Transmission Fluid Flush
Old Jun 30, 2012 | 04:40 PM
Raccoonrider's Avatar
Default Automatic Transmission Fluid Flush
I recently bought a 94 Accord with an auto transmission. It has 180,000 miles on it. The last time the transmission fluid was changed was 80,000. I want to change it again but i have some concerns. I know the fluid was not changed with honda fluid first of all...and I have heard that doing a flush at high miles is very hard on the tranny and not reccomended.....But I have also read that NOT using honda fluid is very bad for the transmission...So im wondering if i should get it flushed or drain/refill with the dw1 atf. Any input on this is greatly appreciated.
Old Jul 1, 2012 | 07:09 AM
Please post questions like this in the General Tech section....I moved this one.
I would drain and fill with Honda trans fluid. Might do up to three, drive a few miles between changes.
Old Jul 1, 2012 | 09:30 AM
moey's Avatar
I did two drain and fills at 170k on a 96 accord that did not have honda auto fluid in it, the transmission seemed to shift a bit better afterwards. When you do a drain and fill your only changing ~2.5 quarts of the fluid basically taking the plug out and wiping it off and putting new fluid back in. I cant imagine causing damage doing this.
Old Jun 8, 2021 | 12:27 AM
Steveolv's Avatar
Default Fluid
I wouldn’t use DW-1 on a 94. I believe that tranny used Dexron III from the factory. DW-1 is supposed to be backwards compatible but I don’t know about that far back!
My 98 came with Z1 in 98, and I find my car does better with the “Valvoline Import” which is a (can be used in) Z1 applications in my case. For your car I would probably go with a Dexron IIIh or the Valvoline Import but not Dexron VI.
pmay805
Jun 7, 2021 11:52 PM
5.0stang
Apr 24, 2013 08:29 AM
KD1977
Jan 6, 2012 12:58 PM
92Wahoo
May 28, 2008 06:28 PM
Secretspot
Oct 24, 2007 03:40 AM
