Average Gas Mileage (1996 4 door EX 4 cyl)
Old May 7, 2009 | 10:15 PM
AceTheAce
Default Average Gas Mileage (1996 4 door EX 4 cyl)
I have taken multiple readings on my Accord and have had disappointing results. I have gotten anywhere from 20mpg up to 22mpg. A small 4cyl car should be getting much higher, right? I try to drive smoothly and use cruise control often so I have no idea what could be preventing me getting closer to 30mpg.
What mechanical items could be malfunctioning (or just not working well)?
Old May 8, 2009 | 06:19 AM
hondadude's Avatar
You have to start with the basics, air filter, spark plugs, plug wires, dist. rotor, tire pressure.
Clean the throttle plate area with carb cleaner and a soft bristle brush [toothbrush]
Are you sure the trans [automatic???] is getting into lock up at highway speeds.
Brakes dragging, like a stuck caliper pin on the front calipers.
EGR stumble at light throttle [1500-2000 RPM] ??
Lots of red lights on the way to work each day?
Old May 8, 2009 | 02:35 PM
AceTheAce
I took it to the Honda dealer when I bought the car and they replaced much of what you mentioned. I got brand new Michelin tires so I wouldn't think it would have to do with the tires. What do you mean getting into lock? Like low RPMs? If I set it on cruise going 70mph I usually am around 3,000. I will look into some of the other things that you said. Thank you so much for your help!
spohney
Jan 29, 2014 02:13 AM
cyberplaid
Sep 12, 2013 09:01 AM
bigrudolph
Jul 4, 2008 01:36 PM
itzztrick
Mar 14, 2007 08:53 PM
1995accord
Apr 29, 2006 04:32 PM
