axle problem 93 accord F22, 5 speed
Old Feb 4, 2010 | 05:56 PM
mcinnesja's Avatar
Default axle problem 93 accord F22, 5 speed
Sorry for not looking throu all the threads guys
(the search funtion did not help much)
But I am trying to remove the passenger axle from a 1993 5 spd.
We removed the axle nut, dropped the lower ball joint, so the hub is out of the way like we where told to do.
Now we got stuck, the axle wont come out more then an inch.
We tried turning it and using a pry ball(gently)
But with no luck
What did we do or not do right?
Old Feb 4, 2010 | 06:13 PM
Which side is stuck, the spline that goes into the hub or the one that goes into the transmission?
Old Feb 4, 2010 | 07:05 PM
mcinnesja's Avatar
Sorry, forgot to add that
Its stuck in the tranny itself.
Old Feb 4, 2010 | 07:41 PM
I used a flat pry bar to pop the inside part out from the transmission. There is a snap ring that holds it in place. I couldn't just pull that side out of the transmission.
Old Feb 4, 2010 | 07:52 PM
mcinnesja's Avatar
Thanks
We tried that , but I guess maybe just with not enough force
Will it hurt it anything if we turn it?
And we dont have to pull the drivers one also do we?
(read somewhere that you might have to)
Old Feb 4, 2010 | 07:58 PM
You will only have to pull the passenger side.
You can turn the axle in the transmission as long as you are in neutral.
Just be careful that you don't damage the seal that is in the transmission. Make sure that your pivot point is on the transmission case and you put force on the axle out.
Old Feb 5, 2010 | 12:23 AM
91excoupe's Avatar
when you pry on it, you cant just simply put smooth force on it... it takes a bit of a jolt to "convince" that snap ring to let loose... just put your bar in there like your just gonna put even pressure on it, then put a lil space between the axle and your bar and then pry with a snapping motion... it'll usually pop out on the second or third jolt. when it does pop loose, just pull it the rest of the way out... then when u install the new one, line up the splines and gently push it in till you feel it bottom out, then give it a little shove to pop it back into place... you will not hurt the new axle pushing on it. hope this helps, and good luck
Old Feb 5, 2010 | 07:18 AM
Make sure the car is supported real solid. You might not want it toppling off a jack...
Old Feb 7, 2010 | 03:58 PM
mcinnesja's Avatar
Its up on a hoist, so its supported
We still cant get it out thou.
Seems like maybe the c-clip might have bent or something
No matter how much we pry on it, (including the jolting) it refuses to come out more then an about and inch to a 1/2 inch.
I must say I am completely stumped on this one.
Thanks for the advise everyone
Old Feb 8, 2010 | 06:38 AM
That's strange, because when the C-clip hangs up the axle doesn't hardly come out at all. Not 1/2-inch anyway. Are you sure the outboard end of the axle isn't hung up on something?
maverick2k7
Feb 5, 2011 08:59 PM
96FiveSpeed
Feb 5, 2010 10:39 PM
AbaZ
18
Jul 16, 2008 10:23 PM
SpanishN00b
Jul 29, 2007 07:11 PM
nixalot
Jan 25, 2007 02:02 PM
