A and B solenoid stuck on BX7A V-6 tranny
Old Mar 24, 2014 | 01:49 PM
Clevor's Avatar
Default A and B solenoid stuck on BX7A V-6 tranny
What is the best way to get the solenoid housing off the tranny? I removed the 5 bolts but it's stuck to the tranny due to the gasket. I tried a 1/2" chisel and small hammer between the housing and tranny but it's distorting the aluminum.
I need to remove the solenoid for reuse as I'm rebuilding the tranny. I imagine there are three methods:
1. Pry bar under the solenoid towers
2. Pulling hard on the towers (as it's the only place to grab it)
3. Large 2" chisel and a sledgehammer under the housing
4. Using a slide hammer hooking under the solenoid towers
I am worried about damaging the solenoid as it's a $300-400 part. If it was bad, not a big deal damaging it on removal, but the part is still good.
BTW, isn't there small screens on one end of the two feed tubes under the housing?
Old Mar 24, 2014 | 04:12 PM
Turtlehead's Avatar
Try using a block of wood against the solenoid and hit the wood with a good sized hammer or a dead blow hammer. If that does not work then I would gently heat it with a plumbers torch and hit it again using the block of wood/hammer.
Old Mar 24, 2014 | 08:53 PM
bpp's Avatar
bpp
I am pretty sure there are 6 bolts holding it. I replaced it once and I dont recall even the mildest amount of difficulty. Amazon shows 6 bolt holes in the pic for the part:
Amazon.com: Honda Acura Transmission Dual Linear Solenoid 28250-P6H-024: Automotive Amazon.com: Honda Acura Transmission Dual Linear Solenoid 28250-P6H-024: Automotive
Old Mar 25, 2014 | 11:13 AM
Clevor's Avatar
Originally Posted by bpp
I am pretty sure there are 6 bolts holding it. I replaced it once and I dont recall even the mildest amount of difficulty. Amazon shows 6 bolt holes in the pic for the part: Amazon.com: Honda Acura Transmission Dual Linear Solenoid 28250-P6H-024: Automotive
Actually I probably did take off 6 screws because the one between the towers holds the trans line bracket so I got the wrong impression when I mentioned it. This solenoid isn't as easy to remove as the one with the rubber gasket and screens since that uses an O-ring seal.
However thanks for the link! $89 sure beats $389 for the OEM part from Honda. I may consider putting in a new one on the rebuild as it would be a hassle to remove this solenoid on the car if it goes bad.
Old Mar 26, 2014 | 01:31 PM
Clevor's Avatar
Well figured out the problem, Doh! I did not detach the solenoid electrical harnesses from the unit when I tried to remove it, thus I couldn't see the bolt underneath!
Thanks for the info, bpp. Because I was about to use a long stick of lumber to pry the solenoid off. With the bolt still on there, it would have damaged the solenoid towers for sure!
robbierob02
Jan 17, 2015 11:49 AM
Clevor
Apr 17, 2014 12:16 PM
Clevor
Nov 12, 2013 06:21 PM
jayallen40
Apr 27, 2007 09:00 PM
