B7XA Transmission rebuild question
Old May 16, 2011 | 02:30 PM
Aggie07's Avatar
Default B7XA Transmission rebuild question
I apologize if this is not in the correct section. This is my first post here.
I have a 1999 Honda Accord V6 with the B7XA transmission. As with many others, my transmission was shot and needed a rebuild. I decided to tackle the job myself, carefully following the overhaul manual (especially torque specs).
I test drove it on Saturday and it shifted beautifully. Better than ever in fact. However, the next day I went to drive it and I got a rough 1-2 shift. Turned out to be a bad pressure sensor and is fixed.
Now the only issue I am having is the range selector on the transmission. Whenever I shift from P to R, or N to D, I feel a very firm shift into gear. Almost a clunk, but not quite that bad. Any ideas on what this could be?
FYI: I used genuine Honda fluid (learned the hard way a couple years back to only use Honda fluid) and have checked fluid level 3-4 times with it OK each time.
Old May 16, 2011 | 04:58 PM
Did you check the condition of the motor mounts? It can cause a clunk, especially shifting from P to R.
Old May 17, 2011 | 08:35 AM
Aggie07's Avatar
Thanks redbull-1. I had not checked the motor mounts but will do so this weekend. I would imagine the stress caused when lowering the engine so much to remove the transmission could certainly damage a 12 year old motor mount.
Clevor
May 30, 2014 02:53 PM
mrcpelayo
Jun 30, 2012 01:02 PM
lgrouper03
Dec 24, 2011 08:21 AM
AccordCroz
Sep 15, 2010 03:08 PM
Et5291
Dec 24, 2009 11:06 PM
